How to Open a Google Pixel Watch
  1. How to Open a Google Pixel Watch, Remove the watch band: step 1, image 1 of 3 How to Open a Google Pixel Watch, Remove the watch band: step 1, image 2 of 3 How to Open a Google Pixel Watch, Remove the watch band: step 1, image 3 of 3
    • Before starting repairs, turn off your watch and take it off the charger.
    • Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
    • Repeat for the other watch band.
  2. How to Open a Google Pixel Watch, Loosen the screen adhesive: step 2, image 1 of 1
    • Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  3. How to Open a Google Pixel Watch, Insert an iFlex: step 3, image 1 of 2 How to Open a Google Pixel Watch, Insert an iFlex: step 3, image 2 of 2
    Tool used on this step:
    iFlex Opening Tool
    $11.99
    Buy
    • The thin seam between the frame and screen requires a thin metal tool—take your time and work carefully to avoid scraping or gouging the watch body or glass.
    • Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
  4. How to Open a Google Pixel Watch, Slice the screen adhesive: step 4, image 1 of 3 How to Open a Google Pixel Watch, Slice the screen adhesive: step 4, image 2 of 3 How to Open a Google Pixel Watch, Slice the screen adhesive: step 4, image 3 of 3
    • When slicing the screen adhesive, insert the iFlex no deeper than 3 mm to prevent damaging internal components.
    • Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
  5. How to Open a Google Pixel Watch, Pry up the screen: step 5, image 1 of 2 How to Open a Google Pixel Watch, Pry up the screen: step 5, image 2 of 2
    • Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
    • Twist the iFlex to pry the screen up.
    • Don't try to fully remove the screen just yet, as it‘s still connected to the watch assembly by a delicate cable.
  6. How to Open a Google Pixel Watch, Swing open the screen: step 6, image 1 of 3 How to Open a Google Pixel Watch, Swing open the screen: step 6, image 2 of 3 How to Open a Google Pixel Watch, Swing open the screen: step 6, image 3 of 3
    • Be careful not to strain the screen assembly cable when you open the display.
    • Swing the screen open to an upright position.
    • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
2 other people completed this guide.
Dominik Schnabelrauch
247,966 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,788 Guides authored
1 Guide Comment
What kind of adhesive is needed?
Rob Novak - Reply
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 130
All Time: 4,406
